Because you partially lose the downforce (aerodynamic benefit) gained from having a front or rear wing if you stall it. There is the result is that you may be able to run more front wing but that's a secondary result.How is reducing drag not an aerodynamic benefit?
Chalie Whiting said:F‐Ducts are not banned. At the end of 2010 everyone was using driver operated F‐Ducts. The regulations that were changed specifically banned the use of driver movement to influence the aerodynamic performance of the car. This got rid of that generation of F‐Ducts.
What some teams are doing now is allowing air to pass into a duct when the DRS is operated. It’s completely passive, there are no moving parts and it doesn’t interact with any suspension or steering systems. Therefore, I can’t see any rule that prohibits it.
F-ducts were never banned, only the driver movement to operate them was and Mercedes have just found a crafty way to use them again.
This reminds me of when IMSA roadracing in the USA banned driver-adjustable boost. One reporter asked IMSA legend Peter Gregg (at the time, the most successful Porsche race driver in history) how the change would affect his team. He answered, "Well, we'll have to be more clever about where we hide it."You're absolutely right. I hadn't considered that.Regardless though, Drag Reduction Systems (DRS) are legal. F-ducts were never banned, only the driver movement to operate them was and Mercedes have just found a crafty way to use them again.
Lift is directly proportional to drag. Downforce is just lift turned wrong way up. So halving or doubling the downforce also halves or doubles the drag.
