Fenderman
Rooters Reporter
Nah, I'm just an amateur!
Back on topic. With regard to ride height at the end of straights. It's worth bearing in mind that the front end suspension of an F1 car is in full compression under braking due to G-forces and therefore the car is at it's lowest possible ride height. I would surmise that in most cases, especially with a low rake set up, the rear suspension would be in full compression as well.
Incidentally, a high rake angle, and thus higher than optimal centre of mass, will induce "dive" under braking. This would require an extreme set up to actually be seen in F1 and/or to be an actual problem in an F1 car. However, a visual.example is commonly seen in MotoGP when a riders' rear tyre lifts off the track surface under extreme braking. The rear wheel lifts since the front forks have compressed to their limit and the G-forces at work continue to propel the rear of the bike forward rotating about the "axis" which is the front tyre footprint on the track surface - not the axle.
Perform an emergency stop in one's own car and one can see (and feel) exactly what I mean. That is another reason why I think the ride height issue is in fact a red herring.
can get my hands on. I can also visualise the flow of fluids, gases and air across shapes. Weird, I know.
