Muddytalker
Points Scorer
snowy said:Not as dull as Valencia surely?!What is it about that tack?
I don't know though... Barcelona is always a procession and I suppose that is very Dijon like.![]()
But Barcelona is still fairly flat.
Dijon, Spa, Interlagos, they all have elevation changes. I should sit down and do soma calcs to prove it, but I have a theory that the negative effect on the following car from a leading car is reduced on a slope, whether it be uphill or downhill.
"Aha! But what about Monza?!" I hear you cry. Well, Monza had slipstreamers before wings/aerodynamics were so major, and before the chicanes - Pre-chicanes, Monza was effectively a Nascar track, with 4 straights connected by 4 fast bends. You could argue the same about early Silverstone. Now, if you opened up these two tracks to their original layout, the wings on modern F1 cars would be reduced (and I bet Newey would try and make the Red Bull run without erm, wings), and you might, just might get a return to the slipstreamers.
So the formula would appear to be - Either lots of up and downs, or if it has to be flat then make it fast with minimal braking.
cider_and_toast said:In recent interviews with Herman it's quite clear that while he overseas the construction of the circuit he gets a lot of "Ideas" from a well known grey haired gentleman of limited stature.
Tilkes (or is it Bernies) problem is that he seems to rely on the same trick at every circuit which is the long straight followed by the low gear corner. Let's have some variation Hermie, please.........
Bernie wants tracks with sponsors visible everywhere, and in view for as long as possible that's his sole requirement.
) and Ferrari World...
