I agree that a reduction in engine size and rewriting the technical regs will ultimately prove beneficial to the sport.Fuel restrictions are also another good thing.
The powers that be at the FIA have woken up and smelled the coffee and realised that unless F1 takes real action in terms of green credentials (thats todays realities) like it or not the sport will come under ever increasing scrutiny.
Restricting the engine power however was for different reasons.Even todays cars have way more than enough power to cause driver blackout in corners.
The fact that they don't is that the cars today cannot generate the aerodynamic grip of previous years cars due to wing restrictions introduced in the last couple of years and this has reduced corner speeds.That is the reason why most lap records even today were set in 2004 and also in 2004 traction control was allowed.
The ground effect cars were banned for much the same reason.Very high cornering speeds was causing drivers to suffer blurred vision, let alone the very spectacular results when the car came "unstuck" for any reason.
I am looking forward to 2013 and the new regs.I know ground effects are due to be allowed then but this will not mean a return to the "sliding skirt" systems used previously.
The 2013 cars will generate the ground effect by clever monocoque floor designs which will reproduce a somewhat similair diffuser effect without all of the turbulence of todays aero systems.
This will result in much better closer racing.The cars will be able to follow each other closely and also overtake.
Tim Routsis of Cosworth has some interesting comments on the 2013 engine.
http://www.grandprix.com/ft/ft22602.html
x2
