The battle to influence the FIA on the proposed changes to the engine regulations for 2013 is starting to hot up. Tony Fernandez has commented that the new engines regs will be a "huge step forward for Formula 1's image" whilst Luca do Montezemello believes there is still time to change the FIA's mind on the 4 cylinder route.
A chance for you to voice your opinions. Do you agree withNick Tony or Luca or is there another way forward for the "pinnacle of motorsport".
Personally, I don't think whether Ferrari plan to put a 4 cylinder engine into one of their cars is of any consequence as to how F1's rules should be framed. I doubt Red Bull plan to put a shaped underbody on their drinks can so is this a reason to argue against this change?
This new engine formula may well draw in other companies and, perhaps, this is what Ferrari are concerned about; after all the BMW 4 cylinder turbo wasn't a bad "little" engine back in the early 80's was it? However, I question whether any form of motor racing should be driven by environmental considerations (unless that is what is specifically set up to do), especially as the fuel used in races is such a trivial amount compared to the carbon footprint of the circus itself.
"We're not going to build four-cylinder engines for our road cars. A four-cylinder engine seems a bit weak for the pinnacle of motorsport. Why could not agree on a turbo V6? If there is the slightest possibility of delaying the four-cylinder, I'll try to get it. I sense a possibility and we need to drive to do it. "
