"We run quite a high rake angle in our car. So inevitably when the rear of the car is higher, the front of the car is going to be lower to the ground.
Frankly Horner is becoming an embarassment to Red Bull and F1 and seems to consistently be putting his foot in it.
Yes, our front wing flexes, yes its illegal. The only question is what the hell you're going to do about it
Hack: {Martin Whitmarsh/Lewis Hamilton/Ron Dennis/Paddy Lowe/the late Bruce McLaren via Ouija board} thinks your front wing is illegal. How do you respond to that?
We think its fine, its passed every test the FIA have put infront of it, move on!
I don't know what any of that means, Bro.Horner can say what he likes.
The images and video are all the proof I need.
And his explanation is, quite frankly, insulting:
Because it's nothing to do with the rake of the car or the back being higher than the front.
The wing (and nose) clearly flex and lower under aerodynamic load.
Horner's statement is a load of hogwash and insulting to those of us who are able to see the facts for ourselves.
Ross Brawn said:There's a regulation which says that the bodywork should be rigid. We all know that's impossible because everything moves. It's a question of degrees, so the FIA has a series of tests to measure the degree to which bodywork moves and, as long as you pass those tests, then your car is to all intents and purposes legal.
Those tests can change, in fact they changed over the winter because, as they do in a lot of areas, the FIA try and improve those tests. There's a new test this year. Red Bull obviously pass it so that's all there is to say about it.
with the FIA having found no problem with the visible flexing of the RB7's front wing
Am I the only one who can see the obvious problem with that statement?
Bit unfair on Marco Simoncelli..We're a bunch of Sideshow Bob's!
As some others have said before me, I'm torn between awe of the prodigious engineering that goes on in the background, and the blatant (at least spirit-of-the-)law-breaking in the foreground.I'm going to fall back onto a point made by McCabe (again). Red Bull have been investing an awful lot of time in computational fluid-structure interaction modelling. This couples deformation in structures to changes in fluid flows and models the feedbacks between the two. It's pretty impressive stuff, but... if your structure doesn't deform then it is a complete waste of time and money! Yet again (see: wingtip skid plates) Red Bull's actions speak louder than the words.
http://mccabism.blogspot.com/2011/04/how-red-bull-simulate-front-wing.html
