Red Bull have "unofficially protested" Vettel's speeding penalty in Singapore. Using their own telemetry Reb Bull have apparently proven that Vettel was not speeding, rather it is the system the FIA use which was at fault. The car's speed is calculated by the time it takes to cover set segments in the pit lane, rather than by laser or radar, which means the line the driver takes through the segment can effect the speed calculated. Vettel was 1.4 km/h over the speed limit.
I presume Red Bull's desire is to make sure it doesn't happen again in the future but this does present a bit of a dilema. If the FIA put radar guns or lasers to measure the pit lane speed what chance is there that a driver, knowing where these are positioned, will make sure they are at the right speed when passing the speed trap? The only option I can see, if the timed segment system is used, is for there to be a white line which the drivers must follow into and out of the pit lane to ensure the measurements are taken over exactly the same route.
Anyone any other ideas?
