Pre-Season 2018-2019 Winter testing and car launches
Discussion in 'Formula One Discussion' started by Greenlantern101, Nov 26, 2018.
  1. If I remember correctly he did
    to remove all adverts.
  3. BradMan
    BradMan Test Driver
    I trying to get use to you and that avatar pic.
  4. Ruslan
    Ruslan Rookie
    So by this calculation (and it is an imprecise calculation based upon a set of assumptions).....Haas is the second fastest car in the field. Does anyone actually believe this? If not....then must we conclude that the rest of the calculation is incorrect?
  5. BradMan
    BradMan Test Driver
    Add to this...
    What do we make of this? Has Newey pushed the limits too far, once again, seems so based on this report. Tight packaging... Aggressive shape. They sound so assuring in fixing the problems. Drivers more muted
    Honda to revise packaging - Pitpass.com
  6. Angel
    Angel Pole Sitter Supporter
    Featured Threads:
    2
    Yes he certainly did. He and Craig Pollock set the team up together more or less.
  7. RasputinLives
    RasputinLives I don't believe in Zimmerman Contributor
    Featured Threads:
    60
    *shudder* Craig Pollock
    Angel likes this.
  8. as you said the calculation is based on a set of assumptions, if one of the assumptions proves incorrect then the calculation turns out to be incorrect. IMHO no one showed their real potential, their simulators are so advanced that they can use the simulators to find out how quick they are and they use the track time just to test some parts (I would assume everything that is affected by temperature, friction, and a few other things)
  9. Izumi
    Izumi Rookie
    Tuesday 5 March at 08:58 : Mar.5 (GMM) The FIA has clamped down in various 'grey areas' of the engine regulations ahead of 2019.
    One unnamed engineer told Auto Motor und Sport: "We have received more technical directives for the engine than ever before."
    It follows a period of intense speculation about the so-called grey areas of loopholes in the highly complex power unit regulations.
    "We have become stricter in all areas where the engine manufacturers could theoretically overstep the mark," confirmed FIA race director Charlie Whiting.
    Why is FiA doing this? It seems like as soon as a season starts, FiA begins (again) to "correct" grey areas, which basically is nothing more then resolving deficiencies of their own, work. Why now, instead end of last year? How does this late pre-race meddling will affect individual teams,
  10. F1Brits_90
    F1Brits_90 Race Winner
    Featured Threads:
    5
    i highly doubt they would be 2nd best car. but who knows & i thought as he had a amendment i post it too
  11. Izumi
    Izumi Rookie
    Your credentials Publius actually suggest I should listen to you, although I am surprised (bold) reading this. I've always thought that data acquisition at the track has been used for correlation with data collected on dyno and elsewhere. How else you discover errors in the system?
  12. vintly
    Featured Threads:
    3
    I would have thought that a cold circuit is ok for testing the durability of various part of the car, including the driver to an extent, but the finer detail of exactly who is faster than who on a hotter circuit is another matter. We can assume some of this but to say who has the second fastest car etc is pure guesswork at this stage.
  13. Angel
    Featured Threads:
    2
    I suppose we're all guesstimating what will happen. No one will be sure until qualifying in Australia, that is when we'll get a true first sign on who is where and what we can expect. That isn't far away now :D
    F1Brits_90 likes this.
  14. Izumi
    Izumi Rookie
    I am actually not certain who has best car. I don't believe in fixation with "fastest" car. Vettel often won a race, yet he was down in 5th place in speed trap. I think being stable in turns when a driver steps on it at the exit is far more important. In era when cars are fraction of a second apart, processing circuit in turns can give a driver gain or loss over others. Sure, you want agile car, but being fastest (in speed trap)? How that translates into wining races?
  15. Bill Boddy
    Things like corner speed and grip whilst accelerating are usually more important than outright speed.
    BradMan likes this.
  16. Izumi
    Izumi Rookie
    :goodday: That's what I thought as well. Mr. Horner once voiced his opinion that Vettel won his races with RBR based on his efficiency in processing turns.
  17. vintly
    Featured Threads:
    3
    Izumi I didn’t mention anything about speed traps or winning races so I don’t know what you’re on about.
  18. Izumi
    Izumi Rookie
    Oh OK, you mentioned speed of a car, and I thought you were talking about speed as in speed trap, whereas I usually think about different attributes.
  19. vintly
    Featured Threads:
    3
    Izumi i didn’t mention the speed of a car either. Please be careful when reiterating any points I might make. I try to choose my words carefully so would greatly appreciate it if you did too.
    gethinceri likes this.
  20. BradMan
    BradMan Test Driver
    Just saw this..
    I've forgotten how intense driving a f1 car really is, with all dem buttons. So many things to remember and take care off, including fiddling with buttons, adjusting brake balance etc. He even let go of the steering wheel to feel the car...
    I'll have headaches after a few laps...
    Formula 1 on Twitter
    rufus_mcdufus likes this.
  21. Izumi
    Izumi Rookie
    Under normal conditions pilots of A380 have less to do than Kimi had on that one lap. Car is constantly vibrating, and it is wonderful how with his thick gloves he can find those small knobs on his control panel.
Share This
    Dismiss Notice
